Hi!
I believe DAM functionality is on the roadmap. Was wondering what is planned for keywords. Currently adding keywords manually is tedious.
- Will we be able to setup hierarchies as well?
- Will we be able to export including keywords added in Peakto (currently not possible)? This means either adding it to the xmp file or adding it to the jpeg. Would even be better to add it to the DXO dop file as well.
Also, please look at the workflow as well. Currently, you can input a keyword for an image, but if you then want to go to the next image you have to select the next image with the mouse to make it active, then make the keyword field active again to enter a keyword. In Lightroom you can use cmd - right arrow I believe to advance to the next image.
Anyway, so far loving Peakto!
