Usability of face tagging has some weaknesses
I'm new to Peakto 2.4 and in the process of face tagging. First, the recognition quality is often surprisingly good – congratulations.
Second, usability and handling is (in my eyes) overly complicated and partly surprisingly poor, sorry to say so. Am I correct by assuming nobody of the dev team has experience with Aperture's faces? Apple put in  some pretty amazing usability there. Peakto's usability is often the opposite of amazing. Or – maybe worse – there is a better way of handling, but well hidden and not easy or intuitively to be discovered?
Maybe I just need to learn much more, but I'll try to describe the things which I find annoying:
  1. Change of focus in the window view: Why make things soooo complicated?
    1. in the window view of "untagged faces" I often see clusters of a couple of faces of different persons I can tag with a name.
    2. Selecting one cluster, checking if it's content is correct (while remaining in overview window) and tagging the name to the cluster, changes immediately the whole view.
    3. Instead being able to tag the other familiar faces, I get a couple of new clusters. The content of the window is constantly changing and creates more stress than necessary. I get angry because of this poor usability.
  2. Tagging multiple clusters at once – how?
    1. in the window view of "untagged faces" I often see clusters of 2...10 images. Sometimes, depending on thumbnail size, three or more clusters are of the same person.
    2. How can I select all clusters belonging to one face (after checking the cluster has only correct positives) and apply one tag for all selected clusters?
  3. I had to learn the first thumbnail of a cluster can be misleading very much.
    1. Often it really contains the faces of one single person - great.
    2. In some cases it's terribly wrong and contains dozens, few times hundreds of profile faces from awkward angles.
    3. If I then "believe" the cluster thumbnail and don't check the cluster content first, it becomes very time consuming to clean out the "false positives" of a cluster.
    4. Sometimes it's easier to mark the "correct" faces and tag a new name to them, then apply a different tag name to the false positives and rename the old face cluster.
    5. But Peakto is rather slow and hesitant to get the idea, so this workaround might have success or bad luck.
  4. Low quality of a face image – can I adjust the level of recognition?
    1. It's great that Peakto can detect faces far in the background, drowning in bokeh swamp. Unfortunately pretty useless.
    2. It's no point in tagging blurred faces. Can I set up a default minimum quality somewhere? Currently there's "Strict clustering" activated, but I don't reckon this to be a limit for image quality?
