Hello,
I deal with fashion, fashion shows, and deliver contents based on facial identity. I've been evaluating Peakto's facial recognition features with great anticipation. One aspect that could use enhancement is the ability to see example faces from the popup menu used to assign faces.
Example: Many of the faces I need to tag are not familiar to me. I'll get headshots from agencies and "load" them into Peakto to use as the basis of facial training. Many of those faces look very similar, causing potential confusion when attempting to assign faces to untagged photographs.
It would be *fantastic* if the popup menu used to select faces for untagged photographs (the 1 - 5 menu) allowed you to hover your mouse cursor over each selection and see a popup window of faces that have already been assigned to that person. This would aid greatly in helping to tag faces that I am unfamiliar with by comparing the face visually with examples from each of the 1-5 options in the popup assignment menu. Thanks!
